Been hearing rumors of several new S-series combines burning up. Does anyone know about fires in the new combines? It sounds like the exhaust temps get to 1600 degrees F during a regeneration process.
I'm not saying at all it's a Deere problem, and anybody that has ran a 10 series case ih combine should know about chaff on the engine deck and about combines running hot, a local farmer with 7010s about three years ago had a bunch of problems with fires starting in the engine compartment but i can't remember the reason for it.Just looks really sad and scary to see a machine go up like that, any machine will go up, and Deere are not the only combine running "HOT" emmissions these days, all comes down to the guy running it to keep it blown down each day, we have had the "S" machine as a proto for the last 4 years and at present we have a Tier 4 machine with adblue, we have NEVER had any fire issues. Claas have now gone the adblue route with the new 780 with a Merc engine.![]()
YES it VERY VERY Important to keep a combine/cotton stripper / baler blown down every day, its good work practice, I even blow my baler off when doing long moves down the road, point was proven the the other night when a rear tyre blow out on the road at night and until I noticed the smoke in my rear view from a car lighting it up, if the baler was not clean, it would have been a fire ball, it took the brake line off and oil all over the shop aswell. hot engines, drive lines are not a good mix. keep them blown down daily, plus it makes you check the machine for other faults dailyUnless you are in sunflowers or lentils and such you shouldn't have to blow the machine off very day...that is load of bull. You guys honestly feel that is acceptable under normal conditions to have to blow off the machine EVERY DAY?
Lentils are like combining gasoline. If you look at lentil dust too hard it would probably ignite. The only fire issues we've had on the deere's were in lentils
two years ago this fall our neighbors whole compound was almost burned down after a brush fire dropped ambers into their cornstalks from a mile away. In no time there were 7 big 8 wheel units in their ~200 acre field. **** was wild.Those were my thoughts as well...but then I would imagine they did tryI don't see how come more of the standing grain and stubble didn't go up
What does surprise me even more so, is since that combine was marked as #7, I'm guessing this is a fairly large operation and in the middle of some open looking country...that they didn't keep a tractor and disc close by in case of that kind of situationI don't have enough fingers on one hand to count how many of us within a few mile radius of me here, each fall try to keep one tractor hooked up to something and keep it within a mile or so of the combine for just that kind of situation, then if such a situation arises and its obvious you're gonna loose your combine, but at least even if you have to hoof it on foot a mile, if you can get there with something in not too long of period of time and plow up a firebreak so you don't burn up the whole dam country in the process. Thankfully I haven't had to do it on my own land as yet, but I have neighbors who were sure glad to see someone's disc show up when it did, and it only made it there when it did cause it was close by.
throw a match in a bucket of diesel and it will go out.Fj there was a recent thread with burning red machine. Lots of brands go up but as they say misery loves company. Locally most machines are red green or silver and I've seen them all on fire or burned out. Never heard of a case going up because of chaff build up though. We smoked a 1480 once due to a fuel leak, who would have thought that was flamable![]()
They used up 3 fire extinguishers to no avail.The pictures were taken from the guy in the grain cart.It kinda looks like a fire extinguisher would have worked better than a camera... That fire looked fairly small at the beginning.
Just an observation, I wasn't there...
Posting pictures of fires in such early stages might not be wise, insurance company sees this they might fight the claim on grounds of the operator not doing enough to put the fire out. Just a thought.
That makes sense, everything appears different in pictures of course, usually cleaner and less extreme. I hear so many people say "if it started burning I would walk away, who wants to run rebuilt equipment when the insurance company will buy you a new one)...They used up 3 fire extinguishers to no avail.The pictures were taken from the guy in the grain cart.
which area was that?Had a neighbour tell me that three S series have ignited in this area!!
Sounds like a problem to me. All different owners.
We have 6, S670 machines, couple of fires this season, NON caused by the regen or hot exhaust.
