I've tried numerous times to calibrate a new to me 2020 grain table to use on my 8230. It always comes up with a Left Sensor fault code 113, which the Manual agrees with the Monitor as being the left sensor. I sprayed electronic cleaner on all the Connecters involved. It said something about it being 5 volt too. I was never able to successfully calibrate my Drago corn head height sensors last fall either. If I recall, it had basically the same fault issue, not sure tho.
What is the likelihood that it's in the combine harness and not the header harness or sensor? What Ohm meter readings should I get testing the header sensor itself and which prongs on the sensor connector pack do I connect to??
Whew, I hope this makes sense and thanks for any help!!
PS: This combine and headers are new to me since late last fall. I used the corn head manually and this summer I cut oats with it in the manual locked-up position. I would like to buy a draper head but decided to try the 2020 out 1st. It has an Air Reel, otherwise I wouldn't consider it on beans but I've had decent success with a 1020 w/Air Reel on my 2577. I'm almost fearing that I spend a LOT on a Draper head only to find that the Combine is the problem??
