7120 cooling issue
6.7K views 4 replies 5 participants last post by  lanwickum
#1 ·
On my 7120 last year I was having problems with it running warm and we were very diligent on radiator cleaning 2 times a day and still would set the alarm off
This year I used a heat gun to check the temp at the thermostat housing and running at operating temp in the cab it said 183 and on the gun on thermostat housing by sensor I was only getting 154 so I thought I figured it out and replaced the sensor and put a new one in and same readings exaclty!
Not what I wanted to see!! So now what?
Was told it could be my ground wire so that's my next step but was wondering if anybody else had this issue and what cured it if so!? I really don't think it was running that hot I'm sure it has to be something to do with the gauge
Please help if any knowledge
Thanks
#3 ·
I don’t like the temp gun. I have never been able to read the same as a temp probe in water as shooting metal on the outside of the engine with a fan blowing at you. 20-30 series combines have had issues with thermostats. 9120 and 9230s may not be an issue with 7120s. Check your engine fan also . If you can turn your fan either direction and slip the belt then belts are loose or worn
#5 ·
Be certain screens are cleaning, radiator is clean. If you have washed it out when dirty it can be very hard to clean after that. I have had to remove radiators and coolers to pressure wash or send in for a good cleaning after a person washed with a garden hose. Turns the dust into hard sticky chunks that get very hard to remove. Use a light and look through it best you can. Usually one person shining light through one side and look through the other if possible. Make sure the fan is spinning and belt not slipping. Make sure fans fins are in good condition. Make sure radiator is sealed all around and not pulling around the coolers instead of through them. Make sure thermostat is working properly. May just change it out. Maybe do a good system flush. Systems do not often cake like in the past anymore. If it had gotten oil or fuel in the system it may cause a slight cooling problem. If it had poor coolant added it can cake in the system insulating it from proper cooling.
A good check is temp differential from bottom of radiator to the top when system is hot. Use your temp gun to check it. I forget what a good temp difference should be. Engine Motor Cooling | Heat Load Exchange Temperature This may help to give a basic idea. FYI, to much temp difference is also not good. It can mean low coolant flow or other problems.
