04 9660sts leaking grain on rear axle
69 views 2 replies 2 participants last post by  Hefner19
#1 ·
I’m sure this has been asked before but I can’t locate an answer or the problem on the combine myself, but my 04 9660sts is leaking grain in the back near the shoe/chaffer frame and the outer sheet metal. Dumping grain on the rear axle on both sides of the machine. So much that it is building up. Anyone had this problem and know a fix, would be greatly appreciated
#3 ·
That’s what I was thinking as well. Pulled the sieve up out of the way. I think this is the area/seal you and others are referring to. Visually I don’t see an issue, nor do I know how wide the seal was originally. Could it be worn too short? This picture is from the drivers side looking across it
